Torsion Bars
ranger1014
Bobcaygeon Ont Canada
hey everyone i was wondering by cranking your torsion bars does it do any damage to your alignment or is it crank and good to go....
crankin the bars
i cranked mine about 5000 miles ago i havent had a problem with alignment and i had it checked by two different shops go with it man its worth it crank it right though you dont want it lopsided
:headbang:
Always have the alignment checked after doing a t-bar crank. As you crank it up the tie rods get shorter and will be toed in. At a minimum you will need a toe setting done, depending on how much you crank it you might need upper camber/caster eccentrics installed and camber/caster set.
I just cranked my about 200 miles ago and got new tires, no problems. now it look like a 4x4, before I got shock and the t-bars cranked the front sat like a 2wd truck
I cranked my T-bars almost 35,000 miles ago, and haven’t had any problems since. All 20,000 miles on the current set of tire I am running have been added after cranking the T-bars. They are wearing even and have had no problems. Just be sure to lift both sides of the truck an equal amount.
