99_3.0
When you cranked your torsion bars, how much resistance did you have? I jacked up the front so that the tires were about 3 inches off the ground. Jacked up on the tow hook, and put a jackstand on each frame rail really close to the front. Sprayed both torsion bar adjuster bolts with pb blaster and had to use a 3 foot pipe to even turn them. Tires off and no weight on the suspension. Ended up stripping out both bolts but used the next size smaller socket to fix it. I left about 1/4 inch thread left. Anybody run into this?
