Hey guys, heres my problem.
I put 2inch lift shackles on the back of my truck so now I was doing a torsion bar crank. I jacked the front end up so i had enough room to drop the suspension down through cranking the t-bar bolts. When i cranked them, nothing happened. I only tried it on one side, tightened it, i even loosened it and still the front suspension did not move. The catch is my crossmember is slightly bent on the driver side and the torsion bar bolt on the side I tried is slightly bent as well. I live in Michigan, could rust be an issue, could the bent crossmember and t-bar bolt be affecting something? I can post pictures of the crossmember to show how bent it is. Thanks, any help would be appreciated!
