torque spec for wheel bearing nuts?
Greenpig4#4
Tyrone, PA
What is the lbs for the two wheel bearing nuts that are behind the hub. Mine came loose on my ranger and i got he large socket to tighten them and i am having trouble find the torque spec. Help....thanks
the inner is hand tight (spin the rotor while you tighten it to seat the bearings). the outer is 250ft-lbs.
thank you. I think that the double lock nut flange set up without the clevus pin is a poor design. I now know that it aint cool having a 33in bogger going ever witch way but straight, thanks again
you cant have any kind of cotter or clevis pin holding the nut on (as on a 2wd) as there is an axle shaft going throught the center of the spindle.
the jam nut design works "alright"...but fords spec. of 150ft-lbs on the outer nut is nowhere near enough...especially for 33" tires.
i drive the outer nut on mine down with a 1/2" impact.
Yeah, as Wicked said the book spec is 150ft-lbs on the outer nut, but it's nowhere near enough.
I run the inner nut down to 35 ft-lbs, spin the rotor a few times, back it off a half-turn, retighten it to 15 INCH-lbs (hand-tighten it with the socket), put the locking washer on, then tighten the outer nut down to 225-250 or so ft-lbs. Never had one come loose on me (running 35s).
Tighten the nut down to 35 ft-lbs, spin the rotor a few times, back it off a half-turn, re-tighten it to 15 INCH-lbs (hand-tighten it with the socket), loosen to fit the cotter pin.
Note: Year doesn't matter for 4x2.
