torque on t-case rear flange
small ranger
Solid Axle Swap
dirty south
Like the title says. What do I torque the rear flange bolt too? If I over tighten the bolt it pulls on the output shaft and the t-case will not shift out of 4wd to 2wd. Am I missing a spacer?
You must be...
the speedo worm gear on the output shaft on a BW T-case is moulded onto a steel spacer.
BTW, I don't bother torquing it, I just run it as tight as I can get it with
my 1/2" impact gun.
AD
150-180 ft-lbs (use some Blue Loctite on it)
