1986fordranger
- Mar 13, 2011
- Age
- 31
- central VT
- Automatic
hi i was woundering if its posable to use a small propane torch to weld sheet metal on my 1986 suzuki samurai and my 1984 f150 i have herd it will mess up the metal real bad from the heat , the reason why i am asking is i see jc whitney sells a kit to use with a propane torch to weld steel and i thought it would work on sheet metal , if this won't work what do you suggest to use , i also own a 50amp arc welder but i don't know how to use it and i would think it will burn throught alot , thanks , heres the manual i uploaded to my computer for itView attachment 5275
