Topher's EX250 build thread
Pretty Good Idea there !! May I suggest some tubing/tape on bolt as not to scratch the helmet clip-
Hey, I found it... LOL
Cool bike
Sent from my HTC using Tapatalk
I've used a static balancer before, and they work fine. IIRC it can take a little while though, because the tire likes to wobble around a bit.
bubble balancers work fine for large diameter, it's wide rims that they don't work for... because there's inner and outer weights, you should split the weight and place it inside and outside, about 50/50, when you use a 7" wide rim, it won't be noticed as much as a 10" wide...
Good to know. So I guess I probably shouldn't balance a 35" on a 15x10" rim then? Ha.
Nice bike. Keep up the progress.
Upcoming TRS Events
