kcm94
Brought my truck in for an alignment and get my camber set. I forgot to replace the axle beam bushings when i swapped new axles with my lift so my trucks been in the shop for about a week. I have the stage 1 3 inch duff lift and your supposed to use the top holes on your axle brackets. When they replaced my bushings they said the bushings were binding and couldnt get them into the top hole so its mounted in the bottom hole thats for the bigger lift. Is there anything wrong with this?? My alignments getting done tomorrow but the camber is set and looks solid.
