Thats it, Thanks.
They are awful expensive to only need them for the flange adapters.
the rear drive shaft flange bolts are 12mm 12 point sockets.
The front uses torx bolts. That is NOT the only place on a vehicle you will use torx bits. Do yourself a favor and buy a small set of them.
Those are the sizes I have found too. The bed bolts, the front drive shaft bolts, and the seat belt bolts.The only sizes I've found are T-55, T-30, and E-7. Have you found any others?
Get GOOD ones. Shearing off the Lisle crap sockets in your head bolts will cause no end of headaches.
