toggle switch question..
exotic_4x4
hey guys this is a really stupid question..i have an illuminated toggle switch to my kc lights on my truck (with a relay )..This is how my switch is wired...my toggle says
GROUND -- GROUNDED under dash...
ON ACC -- My kc lights (runs a wire from relay to the switch spliced in KC's)
SUPPLY -- 12 Volt power supply
VOLTS
my question is why isnt my switch illuminated? do i need to switch my ON ACC and my Supply volts around?... meaning...(power supply in the middle and my KC lights on the supply volts spot on the switch?)
yeah try switching them only takes a min depending on where the switch is, and it is possible the light in the switch is bad.
ON ACC -- 12V keyed/constant
SUPPLY -- to lights/relay
is how it is meant to be wired for the light to work.
