Other than the one week stretch, the weather here has been warmer than normal. Hopefully that holds until after we are done with the current aircraft work. The hangar doesn't have any heat and tank sealant doesn't cure all that well when it's cold.
High winds, lightning, thunder, and some soft hail came through last night at 2:15 a.m. for about 15 minutes.
A small dead tree from adjoining woods fell across my side yard and fragmented on impact. Otherwise no damage- trucks were parked out of the way of treefalls.
Same massive overnight temperature drop as most of the Midwest is experiencing.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
