to many years of water
chrisvegas72
las vegas nv
now that i gotta do my head gaskets. my block is full of scaly rust how can i get rid of it without pulling my block and dipping it...have to replace the freeze plugs on both sides of the block..can i just wire brush the inside and blow it out...the water jackets that is...
I don't think there is a way short of pulling the block and dipping it. I dug a bunch of rust (BIG clumps) out of a flathead block that sat for 33 years. I did it thru water pump holes and everywhere else while running a water hose and flushing it at the same time. I poked the holes open at the heads and did the best I could with screwdrivers and my fingers and a wire brush. It seems to be fine, doesn't overheat and the antifreeze is still not rusty looking, so the hell with it until I pull it for a rebuild.
If you're truly dead set on a DIY job, Muriatic Acid will work on rust. Should still be available at most hardware stores. You should take good care not to get any on you.
I guarantee taking it someplace would be infinitely less of a headache.
thanks...im gonna try to use small wire brushs and flush with a hose... cross my fingers
plastic hat
can i get the little plastic hat looking tip of a fuel injector...dealer item?...auto zone....helppppppppppppppppp:shok:
fill it with water and take it to the dealer, ask for a coolant flush.
