hot enough the engine quits
With the ac on, driving on highway, it will eventually get hot and start missing and soon quit.
At idle with ac on the engine will quit because of the heat, and take forever
to cool down to be able to start again.
The Carb sits on a 2 inch riser that insulates heat from intake..
I use it to bring torque down in rpm some, as the 2.8L is high rpm torque..
The headers and Y tube in back are wrapped with Header insulation
Its the Stock size exhaust with a high flow Muffler from Napa, I was careful
to install exhaust with no burrs and with all pipe ends facing back of truck so not to resist the flow of exhaust.
I do not want to add fans, and I am not sure fender cutting would work
unless someone else has done it with success.
I am almost ready to just port the exhaust manifold and put it back on
for driveablity. And that means tunning the carb for the exhaust manifold, as now its a sweet runing machine when the secondaries open with headers..
