I use whatever Autozone sells. Usually you buy their stuff (daralast) it comes with a warrenty of some kind. When I got my clutch stuff, it all came from the JY but it was all new when pulled off the truck I got it from (I got lucky there).
Your JY or parts store....
My tranny may be an 83 but Im running in internal slave from an 85 and its bellhousing. That took some engineering but compairing the two setups, got them to work. I dont know if any TK4 tranny's run internal slaves but if not mine works with it.
What is in your truck is a flex plate, the torque converter is bolted to it so yes you will need the flywheel from the other vehicle. As far as the transmission crossmember, not sure but just grab the one out of the donar vehicle an you may be all good, along with the driveshafts.
