tires
KVD7360
Upstate NY
2005
i getting a 4in super lift and 3in body i just order i got a 2005 ranger 4.10 what tires sizes and brand should i get
i love my dunlop mud rovers. I have them on 15x10 wheels and they fit really well considering i only have a 2" body lift and bushwhacker cutout fender flares. the power is not a problem with the 2.9 and 4.10 gears. only thing to watch out for is the backspacing of the wheels. mine are pretty deep and require a 6" flare to cover them. i am also tracking about the same as a f250 with the same size tires.
I'd go with 33's, 35's is just a bit too big and not much more of an advantage other than having a few more pee stops when you fill up your gas tank. I honestly wouldn't bother with the body lift as 33's and a 4" lift look sick by themselves. 4.10 gearing should be good too with the 33's and 4.0L, I had 3.73 and 31's on my 87 2.9L Ranger and it had tons of go in it.
As for brand and everything maybe look for some used tires? That's what I did, then you can get them cheap and if you don't like the sizing or brand you're not out a lot of money. Look for some BF Goodrich AT's or MT's. I had some 31" Hankook AT's and I really like those too, hooked up really good in soft and hard.
thanks yea i got 4.0 with 4.10 is there anything i can do to my hub like getting warn hubs?
I swapped my auto hubs for some warn manual ones. Super easy swap me and my dad did together, pretty straight forward just do one side at a time like you do brakes. Another plus is you get a bit better mileage when they're disengage as opposed to auto's which are also partially engaged.
