It may also rub your radius arms at full steering lock. I ran the same setup and used 2" of washers to fix (I also had access to longer bolts 12M bolts to fit the nut). You need at least a 1" space under the front coils for ti to get better.
You could use large inside diameter washers from your local hardware store or Home Depot or Lowes. Get about a dozen of them (6-ish per side). Or you could buy the spacers on ebay for rangers...
For
