tire size?
94 Ranger
hey guys-
Would a firestone destination 30/10.50/15 fit on my stock 94 extended cab ranger without rubbing?
i ran 31/10.5/15 on my stock 95. it was a 4x4 though. when you go to the tires store ask to take one tire out to see how it will fit.
NW
yeah
mine is 4 wheel drive...ok so i should be good
I have 31x10.5R15s on mine right now...Mine is a 2wd though. Only problem I have is I cannot go lock to lock, but otherwise they should fit just fine.
Think 31's will fit a stock 87 ok?
Guys read the numerous tire threads that are out there. 31's will fit just fine, youmight have a little rubbing, but not enough to hurt anything. The slightest little bit of lift such as tbar crank will eliminate the rubbing. There are guys on here with minimal lift running 32's and 33's.
