LearjetMinako
It would seem people do take pleasure in neglecting their tires. So folks, as a reminder to some on this board. Please check your tires pressure inflation. These pictures explain what could happen if you don't.
thats just ridiculous
on a side note, since youre the unofficial tire guy, have you ever seen a plug work its way back out of a tire?? i had one that had a bolt in it (yeah, like 1/4" and an inch long) so i pulled it out and plugged it. probably 1000 miles later, the tire goes flat and the plug is stuck on the tread.
Yes I have. Usually the DIY plugs that customers can buy are crap. I suggest those to be used only in tractors or non-highway tires. And I repaired a bad tire repair just today. I guess the last guy didn't use the correct size plug/patch and air started to leak from it.
so im better off taking it somewhere? i'd rather not spend the money if i can do it myself. i put 2 plugs in it together but ive only got maybe 100 miles on it since then.
ok since I get conflicting stories about it, how often should you check the pressure??
not that it really matters to me cause I check mine mine evry weekend while I'm at work (I figure I have the tools, time, and air so why not) I also do a walk around visual inspection before I get in it and drive anywhere.
LOL, I am probably one of THE worst about tire maintenance. I haven't bought a set of new tires in at least 5 years. I normally get used tires for $25 a pop, and honestly, people throw out some half way decent tires. Actually, I am helping reduce tire waste on a very small scale. I will roll them till their bald or out of balance. Granted, I don't normally ever need to take the hiway though, I live in the middle of the city, almost anything is within walking distance..
Pete
