harriw
Hey guys and gals,
'94 4.0 w/ AC. I'm replacing my thermostat (lukewarm heater, engine never comes up to temp). Drained the radiator, pulled out the air intake (replacing air filter and cleaning MAF while they're out).
Using all sorts of socket extensions, u-joints, etc., I managed to get all 3 T-stat housing bolts out, but it's awfully cramped in there, and I'm not confident I'll be able to maneuver an RTV'd gasket back in there and get all 3 bolts re-tightened (all beore the RTV hardens up).
Any tips on how to maneuver and/or free up space around there? Looks like my biggest culprits are:
1.) The (metal) AC line - don't think I can do anything about that.
2.) The alternator isn't a big problem, but the bracket that holds it and the serp. belt idle roll is really in the way. I can take off the belt and alternator easily enough, but can I remove that bracket that holds the alternator, idle roll, and belt tensioner? I see 3 good-sized bolts right on the front - any others holding it on? I guess I'm concerned whether alignment of that bracket is crucial for proper serp. belt steering, or if I can pull it off and put it back on without issue.
So what say you? Can I remove them, or do I have to work around it somehow? Any other tips or tricks to free up some room or make the job a bit easier?
Thanks a lot!
-Bill
Thanks a lot!
-Bill
