Timing??
Memphis
Knoxville, IA
How do you set the timing on '94 2.3? Can you? Maybe it isn't possible anymore. I see timing marks, but I know this has coil packs, so......
you can't adjust ignition timing if that's what you mean. but the valve timing is set using the marks on the timing cover to it's corresponding marks on the crank and cam shaft.
