timing
doug free
cecil county, md
put a new dizzy in my 94, im trying to set the timing i know its 10deg. BTDC, i have my timing light, and got it adjusted to the 10 mark on the pully is that where it should b? thanks.
ijust went thru the same thing. pull the little plastic piece out, (the ?name?) located by the battery square plastic it is held in like your other harness pieces. then st the timing at 10 deg. this procedure is like pulling the vacuum line off of the distributor of an older engine. after you set it replace the plug. and you should be set.:icon_cheers:
not sure where the to and fro. just know pull the "spout" connector out and set timing then replug and all should be well. mine was located front of battery behind left headlamp.
