Johnnyboiranger22
- Nov 1, 2017
- Age
- 29
- St Petersburg, FL
- 2.3 (4 Cylinder)
- Automatic
- Tire Size
- 215/75/14
Im still at the 91 ranger 2.3.
First let me put everything i replaced
Water pump
Thermostat
Cylinder head and cylinder head gasket
Cleaned throttle body
Spark plugs and wires
Main belts
Timing crank sensor
Fuses
Fuel pump
Fuel filter
Intake gasket exhaust gasket
So i got it running and I forgot to put cam seal on so i took the cam sprocket off with belt still tightened and got it off put cam seal on and as i was putting sprocket back on i turned the cam alittle bit (so mad) after i got everything back on i cant get it started back up, ive tried timing marks atleast 10 times already, someone mentiones after i get marks alighned that i do a full rotation 2 times but i tried that and i cant get it to rotate. What else could it be? Ive already tried the inertia switch.
Water pump
Thermostat
Main belts
Timing crank sensor
Fuses
Fuel pump
Fuel filter
