zekew64
You've probably got a bad Crank Position Sensor. If you've got fuel and fire, I'm assuming air too, so the system may be mechanically sound (you did remember to move the cam pulley forward one tooth, after timing the engine at TDC, right?), but still be off electrically. The CKP can cause a no-start issue, especially if you've had a front oil pan gasket leak.
