Eric Kropp
So I have a little problem. I was away for about a week and a half and went to start my Ranger and it started after a little cranking and pumping. I either shut it off or it died and when I went to start it again it did this thing like it was hydraulic locked or was trying to start and run backward. Really pulled the battery down. So I charged it up and after a bit of fussing got it started. For kicks I decided to check the timing and was off according to the marks(spout unhooked). So I adjusted the timing where it belongs(10 deg. btdc according to the marks) and won't start. If I back it off aways so the mark is before the pointer about 3/8 to 1/2 inch she runs and starts. My first thought was that maybe I spun the harmonic balancer when it "locked" or tried to start/run backward or what ever that was. My next thought was "I don't think it has a harmonic balancer". Does it? I don't remember one. So maybe the key in the key way sheared off? It definitely runs fine, but that is not fine and dandy as the timing has to be verified in California for the smog check coming up in October. Any Ideas????
Eric
Eric
