- Dec 5, 2007
- 4.0 V6
- Automatic
- Total Lift
- Stock
- Total Drop
- Stock
- Tire Size
- 31x10.5x15
- My credo
- Your character is demonstrated by your actions if you knew no one would ever discover them.
Bros, Engine is 200x (single-digit 2000, i.e., 2001, 2002, etc.). 130,xxx miles. What is maximum allowable deflection of the timing chain, and does it have a tensioner? The truck in question has approximately 3/4" deflection. The teeth on both sprockets appear to be symmetrically triangular, with the valley between the teeth a perfect "U". There is no tensioner mounted. Is the chain worn too much and in need of replacement? TIA.
