Hardwareman
I have a strange noise at idle, and at first I thought it could be my water pump. After running the engine with the serpenine belt off, the water pump and any other pulley in that system was quickly ruled out.
Then I thought it was my camshaft pulley, but now I'm not to sure if it's that or the timing belt tensioner? I can't really put anything up against either because they both spin.
I sprayed some "PB Blaster" on the tensioner about a week ago, when the noise was'nt that continuous and ever since then the noise was worse. It's pretty consistent now, and pretty loud. I was hoping it was'nt a cam bearing, but if it was would'nt it be making noise all the time regardless of rpm's?
Anything above idle is good, and sometimes upon startup I hear the dreaded screech sound of a bearing. Yes, a bearing not a belt squeel. Any help is greatly appreciated.
Allen
Allen
