joemag7
- May 17, 2010
- Age
- 46
I got a '97 Ranger 2.3l w/ 130kmiles
I have good mechanical knowledge, understand engines well enough, but have never changed a timing belt.
I started this project a little over a week ago, but to make the story short I put in a brand new rear timing belt cover last weekend just to find out that the brand new belt won't line up.
The crankshaft is at 0 degrees, the diamond on the oil pump pulley is aligned with the diamond on the rear cover, and the arrow on the camshaft pulley is lined up with th arrow on the rear cover.
Now when installing the belt; starting at the crankshaft to the oil pump lines up perfectly then while keeping the belt tight when I get to the camshaft pulley a tooth of the belt lines up right on top with a tooth of the pulley.
I've adjusted it in both directions, but either way the arrow on the camshaft pulley clearly does not line up.
While holding the new belt side by side with the old belt, the old one is perhaps an 1/8 inch longer, I just assumed that to be from years of use.
The part number from the new belt reads "TX276"
Thanks in advance for any help.
Joe
Joe
