Frank Spadafore
- May 6, 2013
- Automatic
I was driving home, I heard a snap. I knew it was the timing Belt. I replaced the belt. Lined the crank up at tdc. I also lined up the cam and the oil pump pulleys by the two timing marks. I turned the engine by hand to make sure I did not hear any clinking sounds. Things sounded good no noise. I tried to start it but would not start. Then I noticed two more marks on the cam and oil pulleys. Marked the two marks that I used the first time and used the other two. It started up ran smooth, I noticed that I now have a ticking noise. It appears to be coming from # one cylinder. I took it for a drive around the block and also noticed that there is a bad hesiation from a take off from a stop. They say it is a non interfaced motor so the valves should not have been damaged. While I was pulling the plugs had a hell of a time getting # one wire off. I gave a good yank and got to come off. Is it possible that I damaged the wire and the cylinder is not firing correctly? Or am I dealing with a bigger problem like a bent valve or a busted rocker arm or is a lifter hitting the valve cover, due to a bent valve?
