jmabarone
- Sep 2, 2008
Hey guys, Happy Holidays.
I've spent the past few days attempting to get my truck going after replacing the timing belt. I made the mistake of not planning ahead, so I did not leave the engine at TDC when I pulled the old belt. No bother, because I would get the crank in position before putting the belt back on...well, that was 3 days ago and it still is not running.
My dad has helped me the past 2 days to no avail. We have tried repeatedly to time it and it still will not start. Today, I tried it in 2 different crank positions (0 degrees and 360 degrees in a given 720 degree cycle) with the cam mark aligned triangle to triangle and the oil pump aligned diamond to diamond. It smells like it is getting fuel and it is getting spark...so we are all out of ideas.
not sure that it matters too much, but it is a '96, 5 speed, with roughly 140k miles.
thanks in advance,
Jake
thanks in advance,
Jake
