kimcrwbr1
you need the spacer to plug the vacuum leak if you look on the egr spacer it dont match up with the carb the spacer is the same as the stock one and will dissipate the heat from the engine also. you will see when you look at it the one for the pinto is just a gasket the spacer has a gasket on both sides but the carb base has to be real flat to work right that is why I surfaced the carb base the ears that the studs go thru get warped and you lose vacuum around the edge and in the center on the bottom of the spacer. just dont sand the ears too far as they can break if you do when you tighten it down. let me know how it turns out
