kman
I have a 96 Mazda b3000 I have stared getting some noise from my tranny its a 5speed it happens when I push in the clutch it sounds about like its just verly rubbing when u put it in gear it gets louder the wost it gets is in forth if u pull back on the shifted kinda hard. could this be bearing or something inside or is it most likely clutch isn't disengageing completely and I should just invest in a clutch kit? Also everyone talks about the bench bleeding video couldn't u just get one of the vacum hand pumps that u bleed brakes with by sticking in on the bleed screw and use that just make sure u don't suck the resivor dry and that would suck all the air out right?
