- Aug 17, 2007
- central ohio
- 2.5 (4 Cylinder)
- Automatic
- Tire Size
- 235/70/16
- My credo
- the grey-t escape
Today I learned that catolog descriptions can be quite inaccurate. One of the small parts Im needing on my 8N tractor is this special bolt that goes between the lift linkage on the 3-point top plate to the lower lift arms. it also has a tab for the “check chain”- which keeps the lift arms from getting into the tires. Its 5/8” diameter. Mine are so bad that they are wore to 1/2” at least. So I ordered a set, its called “eyelet assembly, check chain”. doesn’t come with nuts but does say it takes 1/2”, so they come in, I can see its fine thread. My next trip into town I stop by tsc & get a pair of 1/2-20 nylon lock nuts. I get home & try them. too small!, I go over to my box trailer & swipe a lugnut, knowing those are 1/2-20. the new nuts fit so it aint the wrong nut for what I was searching for. I grab 2 wrenches from the tool box. the 1/2 wont go over the threads but the 9/16 does, what the hell?! 9/16 fine thread? Ive never heard of a 9/16 bolt/nut. Guess I take one of these new parts into rural king on my next trip to town, they have a better hardware section, if 9/16-xx exists, then they probably have it. If they are going to make things weird then why don’t they include the nut?!
Edit: if I cant find a 9/16-xx I will see if I can source a 5/8-3” bolt & weld a washer to it for chain attachment.
