keifer1122
2000 3.0l ranger 4x4 Driving home from work I noticed the check engine lights on so I almost make it home and the truck starts losing power and bucking then dies I could only start it with my foot mashing the gas to the floor it would fire sputter and die just that quick so I take it to the repair shop and they tell me $1400 and it's my flex fuel sensor so I'm like naw so I go online and buy the $150 sensor that pro1engineering sells to fix my problem. Well that didn't work so I went to oreillys to have them check the codes. Here's the codes
P0176 flex fuel sensor
P1747
P0743
P0750 auto transmission solenoid
P0755 auto transmission plug
P0760
P1451 evap
P0135 o2 sensor
P0155 o2 sensor
P1409 egr valve solenoid
Would this all go away if I pony up for the $600 flex fuel sensor that the guy was gunna charge me $1400 or is my whole computer bad. The guy at oreillys sad he never seen so many codes. As of right now I disconnected the battery and it will at least start and run but when I shift it into gear and hit the gas it sounds like it's missing or bogging and won't go over 2000rpm
P1747
P0743
P0760
P1451 evap
P0135 o2 sensor
P0155 o2 sensor
