breakthru62
New guy here.
So first off.......Hello everybody!!!
I really need some help and this looked like the place to find some answers (good or bad). So don't be shy.
I have a 92 Ranger 4x4 extended cab with a 2.9 liter.
So, here is my problem.........
The lower coiled-spring on the outside of my throttle body broke, so now the throttle stays wide open and won't return closed. This happend a year ago on the freeway during rush-hour. So, I burned up my clutch which is now fixed, but the throttle body needs attention now. So, I'm going to list a couple of questions below and hopefully get some info.
Is there anything I can do to fix this?
Is it possible to get a new spring, or do I have to replace the whole throttle body??
If I can get a spring or the part I need, where can find one online??
Any help or advice you could give me would be fantastic and I will greatly appreciate any and all help.
Thanks, and go easy on a newbie!!!
Scott
Also, while replacing the clutch, I lost the u-joint caps for the rear driveline. I believe thats what their called. The caps that bolt to the yoke.
Scott
