Three ?'s about GT40 heads
BlueChariot
Thomasville, Georgia
'94
Not a swap question, but this seems the most fitting forum.
1. What is the average cost for a set, and how good are they for value-for-money?
2. If switching from stock iron heads, do I need to change anything else for everything to work properly?
3. Did they come stock on anything available enough that I might find them at Pick n Pull?
Used - $100-$250 a set around here, even cheaper if you go pull them.
That depends. What is the bottom end?
96 and 97 Ford Explorer or Mercury Mountaineer. The 98 and up had GT40P heads, which I personally like better (and also have on my Mustang). But the spark plug angle is different than the older production heads and that can make spark plug clearance an issue. But that can be dealt with.
What are you working on?
You might find this useful:
Thanks man! Luckily my buddy texted me saying that when we were at PnP to get by console and bucket seats he saw 3 pair of GT40 heads so hopefully they will still be there. The whole engine is stock, thing even still has the distributor boot on.
Also lucky for me, even after tax due to PnP's fixed pricing the set of heads should come in under $100.
Yesterday I aquired my friend's '91 Crown Vic. Blew a head gasket, luckily and very carefully (even though it certainly wasn't that safe for the car) I got it to my driveway.
Are you considering putting the heads on the '91 vic engine? Might be better off just starting with a 96-97.5 ex engine complete with the shorter fead than trying to do something with the blown vic engine.
Thought you were asking because you wanted to swap it into your Ranger - V8 conversion forum... :) Misunderstood what your intentions were, actually missed the first line of your first post. lol
It's cool. This was the only fitting forum. Teeeechnically it would be "Non-RBV Tech" but since it's a 5.0 I figured this would be a better place. So I shouldn't have any issue boltin on the GT40's and everything being as it should? Aside from the spark plug clearance, is there any other issue with the GT40P's?
Followup quesion, whast the general power gain the the GT40's over stock, and the P's? For the normal GT40's my friend estimated about 30 HP.
The P heads are great. I got a set of cheap headers for mine that clear fine. I have pics in my Mustang thread if interested. The one thing is, they burn a lot cleaner than the previous heads, so Ford eliminated the AIR tube holes on the back of the head. I just re-routed my smog pump stuff a bit and it's worked great.
I also would suggest taking the intake manifold from the Explorer. They are a really nice upgrade as well. Some guys like the Explorer injectors better too.
EDIT: Here's the pic of Cylinder 7 - The only one that might give me a squabble when I change it. It should work OK with an open end wrench on a spark plug socket. Also, I used plug wires for an 89 Blazer for the 90 degree boots for added clearance.
And the other pics (nevermind about going to my thread, LOL):
She's already got 90 degree boots. When I go I'll only have the cash for the heads, I'm debating on what to do with the intake. Is the improved intake found just with the GT40/P heads or are most Expo intakes just a bit better? I'm deffinitely aiming for the P's then. I'm mostly getting the heads early because of the affordability and the fact the stockers are coming off for the new gaskets anyways. After it's running properly I'm gonna start digging into it.
Also, repped for the awesome info. :icon_thumby:
All of the 5.0 Explorers have the GT-40/Cobra style intake. It shouldn't pose much of an issue if you just hook all of your vacuum stuff up. The vacuum locations will be a bit different, but easily adapted. I would also grab the 65mm throttle body. It can be used with a little modding too.
Thanks for the rep!!
Also, all of them had GT-40 or GT-40P heads. The P heads can be identified by the letters GTP that are cast near the bottom right head bolt.
Thanks for the extra parts info. Like I said, I will only be able to afford the heads on my first trip back, but I'm gonna keep the rest on my personal wishlist. I might attempt some light port n polishing using the old heads as practice. Now it's gettin me exicted for the build thread.
Two things here: First is the stock cam in the Vic motor sucks. Big time. The Explorer cam is better by a long shot. Which brings us to the second thing: The Vic's pistons do not have valve reliefs, which may get you into piston to valve contact, depending on the cam profile. The "sploder cam (this is called the F4TE by Ford and was also used in the 94-97 5.0's and 5.8's in truycks and vans) will likely be OK here, but you still need to verify the clearances before running the motor. An HO cam will also likely be OK with this combo. Anything bigger in profile will definately be a no-go. On the plus side the Vic's FEAD (Front End Accessory Drive) is one which many have used in these swaps. But if you can grab an Explorer's FEAD (everything from the timing cover forward, the timing covers on these are unique to the waterpump so you'll need it, it was also used on only a couple of other applications as well.) do that instead, it'll gain you much needed room for a radiator and fans.
