Thoughts on this clutch package?
Short web search, the clutch is made by Exedy which is a good brand. Did some research on their other auctions and it seems the slave cylinder is made by Rhinopac, so at least everything is a brand name.
This clutch is NOT self-adjusting, like the stock clutch. Not sure what the exact difference is, but its likely that as the clutch wears, the pedal will need to go lower and lower, while the stock clutch self-adjusts as it wears.
The OEM clutch is made by LUK, and for about $80 more, the same seller has the kit including a LUK clutch, it would probably be a good investment to just get the better part now.
I agree....can't go wrong with luk. As far as the slave cylinder, I would stick with a well known manufacturer such as perfection, etc. You won't want to have to replace it again due to premature failure.
A new flywheel at the same time will extend the service life of the clutch, and a rear main seal on the engine if there are any signs of oil while your have it apart.
