Thought About This.
87fiveoranger
Does anyone have a tremec transmission in their Ranger,Or could you put one in a Ranger.I have a 87 Ford Ranger and im doing the v8 swap and i thought about putting a tremec transmission in it if it will bolt up.Need some help let me know about this guys.Thanks
Hydrolic or cable clutch?
Does that even matter which you are using? Which Tremec? Even the T-5 is a Tremec now. The newer Tremecs, 3550 and the TKO's take a different bellhousing, same size as the one for the T-5 but different bolt pattern. They also take the 31 spline output shaft, same as used on the C-6. TKO's and the 500/600 series also use the 26 spline input shaft, Don't ever worry about the driveshaft untill you get the motor all set in and aligned. Going to have to move/adjust the tranny crossmember also but no biggy.
Dave
Dave
Well,no.The t5 is still not the same as the tremec,a t5 does not hold 500 ft/lb when the tremec does.The t5 will never be the same as the tremec.
Brandon
Did you get your question answered or not? Sounds like your might have "eduamcated" your self some. I've got a TKO but its the 3550-2.
Dave
