06RangerXLT
so, i think my IAC has gone to shit, or is on its way. when i fire the truck up after sitting for about 8 hours, it revs up to almost 3000, makes a nasty noise then goes to the regular high idle till it warms up. so thats one problem.
my other problem is when it finally calms down and drops to regular idle, its at just over 1000rpm. and its idling rough. normal for my truck is right around 650rpm. now not shaking the truck side to side, but enough that it will slide my ipod off my dash. never would before.
once it warms up, the problem doesnt exist. it fires up fine, idles ok, and runs at the correct RPM.
ive recently cleaned the MAF and IAC, they are plugged in correctly, and there are no codes. my guess is it still in tolerance. when i had my missfire, it took a good 30 seconds of bad running before it caught on and light up a CEL
also, i can tell its high for the idle, because just letting my foot off the brake takes me trough first and into second gear.
Thanks a ton guys, im not to up to date on the computer systems in these trucks.
