Spitfire1975
but how do I hook my transfer case shifter linkage back up? 86 bronco II with the manual t-case. I took it off a while ago to do a transmission switch, and thought I had it hooked up right, but the 4x4 wasn't working. Tried to fix it, still no luck.
When I attempt this again, in what position should the post extending from the t-case (that the linkage hooks up to) be in? Turned all the way forward for 2-high?
