zukirider21
Alright so I'm just finishing up the 2wd 302 swap and I'm already considering tearing the truck apart again lol.
Actually, it wont happen for a good while since I'm going to be taking my time gathering parts up. But for now I just wanna get a rough idea on what I'm going to need.
So far, here's what I've come up with:
EB dana 44 with disc brakes and radius arms
78-79 f150?? radius arm brackets
coils from ???
gotta fab up a track bar and make a bracket that bolts to the frame by the steering gear. probably an axle bracket from ruffstuff?
driveshafts
drop pitman arm
np205 tcase
4wd C6 transmission
some kind of linkage for the tcase
longer shocks and probably axle tabs from ruffstuff
not quite sure what to do for the tie rod that goes from the pitman arm to the other one going between the two knuckles....
I'm getting another C6 to minimize downtime. That way I wont have to pull my trans to rebuild it and convert it to 4wd. I'm gonna do a complete rebuild of it. High performance clutches + bands, possibly a wide ratio kit, r code servo, high stall converter, auto/true manual shift kit, adjustable modulator, and of course all new bearings and seals. That setup will complement the 302 mods that are to come quite nicely and reliably.
I will also be rebuilding the axle before it goes in. New balljoints, tie rod ends, brakes, bearings, seals, radius arm bushings, wheel joints, lower gears, mini spool, and warn or superwinch hubs.
Hows that sound?
coils from ???
driveshafts
drop pitman arm
np205 tcase
4wd C6 transmission
Hows that sound?
