thinkin about another swap?
goodie85
Ford Technician
Winter Wonderland, USA
i watched the youtube videos of the 4 cylinder cummins and i WANT ONE anyone know where the heck to find a complete one with all the computer and hardware? i know i can fabricate alot but the computer i dont think i could.... any info is awesome thanks in advanced
I recommend going for a mechanical direct injection turbo diesel. Then you don't need to worry about the computer. And, I think most Cummins diesels that use electronic control have the computer mounted on the side of the engine. What engine were you looking at? 4bt? B3.3T? Those are a couple of the popular 4 cyl Cummins diesels to swap into road going vehicles.
the 4BT for sure and i did realize the front end issue and i have the solution which is the dana44 swap and i have that in the garage just havent took the time to swap and i have an 8.8 rear in already so basically im in the swap mode and need info on all of the powertrain considerings diesels arent all my thing
if im not mistaken with the diesel being mechanical my speedo and tach wont work either?
Yeah, not quite sure about that one. I think it might, as long as the factory computer is left intact, even if there isn't an engine hooked up to it...maybe someone else that knows better will chime in.
To find a 4bt look for a bread van. Sometimes you can find a bread van (used also by Fritos and other short delivery companies) for roughly $3000 and scrap the aluminum body to make up some of the purchase price (I've done research on this exact swap and read what other people have done). You can also find adapters to mate the 4bt to a standard Ford transmission, such as the ZF, found in late 80s+ fullsize pickups, some of the breadvans already have this adapter and are running a "Ford" transmission, NP435, IIRC. Others of the bread vans run GM transmissions.
To fit the 4bt into your Ranger, you'll probably want a body lift to clear the top of the engine (from the hood) and a suspension lift so the differential doesn't hit the oil pan (they're pretty tall engines).
Ee I'm 17 and I did the 5.0 swap farily easy and I feel I'd be able to do this and I should be able to fund it all by the time next fall rolls around so this is more of a feeler of difficulty and what's needed and basically the fundamentals of so I'm trying to get the info early for when swap time comes around, I may be 17 but I'm not a lazy spoiled 17 year old I work everyday after school and am serious about stuff like this so please just keep it comin with info
