These Wd-40 Cans Suck!
Josh B
Oklahoma
By the time you put enough pressure on the button to get it to spray it's spewing halfway across the yard
I wonder if by removing the spray nozzles one could insert the bare nozzle neck into an older can and use this pos to refill an older can
You talking about those flip up straw cans?
once you use it in one position, it never works right in the other position.
Yes, I left out the photo :/
Thankfully I used it only in the nozzle position. Just trying to quieten some squeaky hinges it used enough for two houses
I could still take it back I suppose, can you get wd-40 in bulk and use spray bottles? I guess that's a no
Yes, you can. I buy it by the gallon and put it in a "PumpAndSpray" bottle.
Brakleen too.
What store do you use to buy it that way? My OK stores are rather limited but there are quite a few possibilities on TX side
In the states try Walmart. Auto parts stores should have it too. Chemical supply warehouse?
Wow, I've never noticed it in gallon cans at walmart
Buy Cyclo Breakaway instead, WD40 is for amateurs.
I use it mostly for breaking up tars, gunk, grease, and grime. it's also good for cleaning taps & dies.
don't have any issues with the flip up tube/nozzle.
do have a gallon of it, if used in hand spray bottles the wax tends to settle out and clog the spray mechanism.
certainly it isn't the best as a penetrating oil.
Amazon.com: Cyclo Heavy Duty Breakaway Fast Penetrating Oil - Case of 12 x 13 Oz - Extended Lubrication Breaks Loose Rusted Joints and Bolts : Industrial & Scientific. $8999 ?
Bastards always lose their pressure too
An occasional shot is fine.
But if you're buying it by the gallon, it may be time to admit that you have a problem . . .
Hey now. I have to regularly spray my add a leafs hahaha. Just ask the ones who attended the LBL trip. But agreed I have a problem I need to address. If I use lithium grease I get about a month and a half squeak free. Regular wd40 only lasts about a week.
