Welcome Visitor! Please take a few seconds and Register
for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
Fixed itLink doesn't work
it looks like the flange is bouncing, that ain't good.This is from the rear differentialIMG_4862.MOV
drive.google.com
Is anyone else seeing the axle twist forwards? It looks at first like the flange or pinion is jumping but the more I look at it it looks like axle wrap.it looks like the flange is bouncing, that ain't good.
grab the shaft/flange at the rear axle and check for any movement other than rotational.
yes it should rotate some when stationary, absolutely no up/down or sideways.
do in neutral
EDIT:
while viewing the video in slow motion it's hard to tell if the diff is rotating down because of torque , or the flange is jumping.
viewing it at 0.2 speed, the flange rotation and diff jumping down occur simultaneously.Is anyone else seeing the axle twist forwards? It looks at first like the flange or pinion is jumping but the more I look at it it looks like axle wrap.
