Derek The Great
- Apr 6, 2008
Hey fellas,
I finally did the tach cluster switch for my tach-less ranger.. I did what i usually never do, I settled on one of the 5000 redlines, which are a dime a dozen.. I used to visit the boneyard in search of the 5500 redline (which is correct for the 4 bangers) but could never find one so this time around i found a donor exploader with a good cluster. Being a 3.0 the redline is 5000.. I did the swap and all was well. The tach works but i dont think its right. i have 3.73's out back and P205R14 tires.
-At 85 mph in 4th the tach reads 3k
-At 70 mph in 5th it reads slightly under 2k (i even attached a pic!)
At 85 in 4th, the engine sounds like it can't take too much more abuse.. In fact, if im in neutral and rev it past 4k, the gas pedal starts to vibrate- that seems all kinda wrong to me...
So, does this seem right to you guys? what are you running at those speeds, in those gears??
Thanks,
Derek
Thanks,
Derek
