Mark_88
- Aug 11, 2007
- Age
- 69
- Ontario, Canada
- Automatic
- My credo
- Love Thy Neighbor
Ever since I've been driving the Ranger (August last year) I've been hearing an annoying squeak from the gas pedal...I finally got around to looking at it last week and greased everything I could see...to no avail.
Yesterday I took the pedal apart and checked it again. It's kind of hard to tell where a noise is coming from when you've got your arms up in front of the seat so you can look up under and work under the dash...and in that position they interfere with sound...
So, anyway, after taking it apart and regreasing everything, and putting it all back together, the squeak was just as bad...so...I checked it from the front of the truck in the engine bay and something dawned on me...
On the pedal there are actually two places for the throttle cable connection...I happened to be using the one on the left (facing the pedal) and had pushed the cable through an appropriate hole...turns out the squeaking was the cable was binding against something because it isn't an exactly straight path to the pedal...
Took it apart, pulled the cable out through the firewall and sprayed some lubricant down the tube (silicone lubricant, not WD-40), refed the line through the second hole and connected the pedal...
No more squeak...
Haaaaaaaaaa.....
Just thought I'd share a minor triumph...
No more squeak...
Haaaaaaaaaa.....
