the slo-vo build thread...
Nice pictures man truck really transformed and I guess it's getting wider
yea im going fullwidth, so it will probably be 2 inches wider at the hub and depending on what wheels i find might have more offset so it may end up being pretty wide but im going to try and get as less offset as i can
what are you doing with your current ttb lift stuff when you go full width?
Guess what. I seen a 5 speed Explorer at Glisson's today.
its going to be wider than 2"s more brother....
its going to go back under my explorer along with some 33's
grab me the shifter :D
technically it will be 4 inches wider per side then the d35, but im running 2 inch adapters right now...so only 2 wider then i am right now
Got you a replacement axle shaft for the one you gave me.
thank you sir, itll be a spare for the ploder
welp the battery died on the ranger today, just so happens that i had been reading a thread on pirate a few days ago about good batteries, a few guys had good luck with the diehard platinum which is actually made by odyssey
went with the marine deep cycle starting battery so hopefully it will be a good one considering it was $200 :annoyed:
Whoa! That's a lot for a battery! Or so it seems anyway.
it wasnt cheap, i had been looking at optima's for a while but it seams since they moved production to mexico quality has went way way down so i decided to pass on them...
almost 900 CCA she cranks over real fast and with the deep cycle i shouldnt have any problems running the winch even if the truck isnt running
the 3 year free replacement didnt hurt either
You should contact Copperhead85, he runs a battery store and can get you a good AGM battery made by Deka for less than the price of an Optima...I got one and plan to get another, these batteries are awesome, and I believe they have the same warranty you have now :icon_thumby:
SVT
oh well whats done is done, had to fix a passenger front wheel bearing just now. started hearing it the other day
they looked fine but went ahead and threw a new one i had laying here in there
