The ranger station glitches and problems!!
BabyBronco89
Solid Axle Swap
GR Michigan
So for the last few weeks I've been using the tapas all app for my iPhone and its great for checking the forums when I'm on the go,
But it keeps on popping up a message that makes me have to relog into the forum to get it to refresh and update its getting to be a pita!!
Here's the message
Also there is a problem in the broncoiicorrall.com tech library where I can not seem to access the wiring PDFs or imgs for the body wiring all the engine wiring diagrams will pull up but not the ones I need
At first I was using the iPad and then I switched to the Mac book and no luck, so I still haven't been able to figure out my tail lights and dome light issues,
Thanks trs!!! I'm sure you'll have this fixed in no time!!!!
Sent from my iPhone using Tapatalk - now Free
newer version of tapatalk is out or something.... it's that way on a lot of forums. Something the admins have to change on their side I think...
It's doing it on my old iPad which is stuck on a way earlier version of the app because I haven't updated my iOS software in a long long time..
It just gets very annoying having to keep logging in to see new posts.
Plus I really could use those body wiring diagrams
I just use safari...
The links for those don't work on a PC either, they aren't there at all.
Yeah I use safari too to access the full site but sometimes the convenience and simplicity of tapatak is nice
Thanks for confirming pcs won't work either, that was my next route!
Well I hope trs can fix it soon I need some cluster lights so I can see when I'm speeding, now that I can again with my 4.0 :D
Also need to finish up wiper wiring and heater blower and radio and dome lights and need to figure out the circuitry on the annoying door pin
For now I my tail light jumper will have to suffice
Stand by guys I'll pass this up the chain.
I updated the Tapatalk. Let me know if it works.
Thanks Jim!!
Tapatalk looks like it is working properly again!!
Any word on the bronco 2 body wiring diagram links?
I need the 86 and 90 diagrams.
Thanks!
Maybe the link in this post from another thread will help ya get by until those links are fixed.
http://search.ebscohost.com/
Just go there.^
Login is tech/tech.
Scroll to the bottom of the page and click on:
Auto Repair Reference Center Beta
That should get you to a vehicle selection page.
Good luck from there.
Once you get your vehicle selected, click "Repair Information" from that menu, and when that page opens click "CHASSIS ELECTRICAL" > "WIRING DIAGRAMS" in the table of contents on the left side of the screen.
Dieseldan,
Thanks for that bit of info I'm not the best at figuring out wiring schematics but that should inch me a bit closer to the final products,
Thanks again!!
