- Oct 10, 2010
- Manual
How about some additional shocks outboarded on all 4 corners with quick release pins (that way the shocks are for on-road use only, and can be pulled in seconds for wheeling)....
SVT
I thought about doing that, and/or moving the shocks out more, but there just isn't room there with how I have things setup. I think its more a case of just not enough spring rate. Which is odd as I'm not the first guy to use these springs. Heck, KyleM's setup is pretty much the same as mine (before he inboarded the springs) so I'm lost as to why I've got such an issue going on.
Hopefully the add a leaf will stiffen up the rear enough to cure my woes. If not, I'll add a track bar to help keep the front 'tighter' which should also help keep the sway from getting out of hand.
So the 60 is coming out?? What would you want for the 60?? I would just want the axle without the calipers or rotors (so you can keep them for your disc brake swap on the 14, or I can give you mine)...I'd be interested if your wanting to part with it....Or I can find a 14 for you and I'll swap you..
SVT
I don't think the 60 is coming out any time soon unless I find a good deal on a 14 bolt. If I were to start from scratch building a 14 bolt, I wouldn't be much money ahead over building the 60 as things sit currently. There isn't anything wrong with the 60 (other than having an LSD) so I can rock that for a while as I get the funds together to regear/lock it. However, if the right deal came along on a 14 bolt, I'd probably go that way.
The right deal would be a SRW with good 4.xx gears and detroit for under $200, and I have yet to see one for that price in my area (seems that the CUCV's were the only ones to get the detroits?).
If I were to sell the 60, it'd be a complete unit (disc to disc).
