- Jun 2, 2009
- Wisconsin
- Total Drop
- 3"/4"
1986 Ford ranger
engine:
1985 Merkur Xr4Ti Bottom end (50K miles)(145lbs compression on all 4 cylinders)
1985 Merkur Xr4Ti head
1988 TC short plenum intake
1986 Merkur Xr4ti Turbo
new O2 sensor
new head gasket
new cap & rotor
new plugs
new ignition module
new coil
new 1988 Large VAM
new BAP
2.5 in exhaust no muffler
Magnaflow High flow Cat
High flow air filter
TRE high flow fuel pump
New in line fuel filter
Brown top injectors
new stock TC fp regulator
88 EEC-IV LA3 computer (no tune)
repinned ranger harness
eliminated:
EGR
no electric fans
ranger external fuel pump
Stock timing (0 degrees BTDC base timing, 10* BTDC spout in)
used the straight edge method for aligning the cam gear
I got the truck running again but it is not making the power that it should. Everything seems to run well but when the turbo spools up I see 10lbs of boost on the gauge, 1400 degrees on the EGT but not feeling any power. The ehaust is too hot at idle but it idles smooth. Fuel pressure is 30psi at idle and 43psi under boost.
I am experiencing lots of blow-by, the pcv hose blows apart and the breather recirculation hose blows out under boost. This is the second 2.3T that I have had in the truck, both have done this.
The first motor had very similar troubles, but a knock picked up by the knock sensor was causing the computer to severely retard the timing. By simply unplugging the knock sensor the timing was corrected and it ran great. The knock was found to be wrecked main bearings. I found another donor car with less miles for much less than rebuilding the first motor. I swaped in the new block and head and was able to sell the rolling chassis.
I have had lots of small problems getting this motor running all along the way but have now replaced nearly every sensor and component. From everything I have read the combination of parts that I have will provide the most power but the truck just doesn't make the power it should. I am not trying to build a bullet proof race car to run on the track and am also on a college kid budget. I have even less money to spend now than I did in highschool so this problem needs to be resolved without replacing every part just to find the one that is causing all the trouble. I CAN NOT afford to rebuild the first motor yet but maybe some day that will be the way to go.
I am looking for affordable suggestions, its not that i dont have money i just cant afford to waste it. With all due respect, if you are not extremely familiar with FORD 2.3 Turbo motors please allow those who are to respond.
I have been at this for a long time and everyone here has been very helpful, but the problem is very specific. At this point it looks like timing or fuel delivery problem. Is there a way I can hook a computer up to it and monitor the timing curves while driving?
engine:
new O2 sensor
new head gasket
new cap & rotor
new plugs
new ignition module
new coil
new 1988 Large VAM
new BAP
Brown top injectors
eliminated:
EGR
no electric fans
