- Jun 12, 2010
- Macon, GA
- Automatic
I'm wanting to do this and searching has turned up nothing. First question is, what year donor vehicle do I need? I was thinking of a 1st gen expO. Or should I go newer? I'm going to keep my fm146 for now then m5 it later down the road. The main reason forr the swap is drivability and efi.
Ok so for the fuel. Could I just run AN braided line and aftermarket efi pump and regulator and use the stock carb'd fuel pickup?
Also I read about the inertia shut off switch, do I have to have one? Or could I use a toggler override switch for the pump.
Also if its not possible to run the fuel lines like I was talkin about(I know I need a return line) what's the bst donor rig to get them off of? What pump to use? And will I have to do wiring for the donors sender?
I'm trying to do this the easiest way possible for the least down time. What yall got for me?
